Boost?
Old Dec 18, 2006 | 05:43 PM
Kartman38's Avatar
Kartman38
Default Boost?
how much should a stock srt 4 be holding and spiking while at full throttle?? and does it differ with different weather temps?
Old Dec 18, 2006 | 06:18 PM
redevil's Avatar
redevil
Default RE: Boost?
you should be at 13,14 and 15 might be the highest..thats holding.stock srt4s dont spike that much, unless u put a boost controller on..then you'll be spiking 20 psi easly
Old Dec 18, 2006 | 06:22 PM
Kartman38's Avatar
Kartman38
Default RE: Boost?
does the air temp. effect it at all?
Old Dec 18, 2006 | 06:40 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Boost?
yes, the weather can affect it by several psi
Old Dec 18, 2006 | 06:46 PM
Kartman38's Avatar
Kartman38
Default RE: Boost?
ok cause its like 30 degrees out and mine was holding between 11 and 13.. so i guess im good then?
Old Dec 18, 2006 | 07:51 PM
Plan B's Avatar
Plan B
Default RE: Boost?
Sounds good to me
Old Dec 19, 2006 | 01:15 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Boost?
That's fine for cold temps and stock, weather definately has it effects on turbo cars boost.
Old Dec 19, 2006 | 01:18 AM
Kartman38's Avatar
Kartman38
Default RE: Boost?
sweet .. thanks much
Old Dec 19, 2006 | 01:58 AM
MAssSrTdriven's Avatar
MAssSrTdriven
Default RE: Boost?
mine runs anywhere from 11-15 it likes to vary depending on conditions so yours is about right. mines stock too btw
Old Dec 19, 2006 | 03:23 AM
71RoadRunner
Default RE: Boost?
Mine spikes 16-17 and holds 15-16 most of the time, it has been as low as holding 13 when the weather was not the best.
