tire issue
Old Dec 24, 2006 | 04:45 AM
greenmachine98's Avatar
greenmachine98
Default RE: tire issue
well all this stuff brings up another question i need answering. will lowering the psi of your front tires give you a bit better grip?
Old Dec 25, 2006 | 01:23 AM
MAssSrTdriven's Avatar
MAssSrTdriven
lowering your tire pressure will make ur mpg go to hell, and will wear your tires unevenly and make you have to get new tires faster, thats about it
Old Dec 26, 2006 | 05:15 PM
04blksrt's Avatar
04blksrt
what will getting the computer flashed do for the car and when would you do that (after what mods?)
Old Dec 29, 2006 | 06:46 PM
MAssSrTdriven
flashing the ecu pretty much just messes with it, and makes the readins from it change up a little bit, ie in alot of cases some companies flash the ecus to make the vehicles pass emissions. i could have sworn they do that on the srts, flash it so it programs to read lower emissions etc. do it whenever you want? or after you upgrade your exhaust.
Old Dec 30, 2006 | 11:49 AM
Burnnout's Avatar
Burnnout
When people are talking about reflashing a Staged Ecu... they are talking about getting it programmed so the key will work to start the car. They are programmed with a Vin number when you purchase them, if you buy a used one you have to get it reflashed.
Old Dec 30, 2006 | 12:46 PM
talisman's Avatar
talisman
Thanks for the explanation there Burnout. I couldn't figure out wtf they were talking about. I work at a dealer and we re-flash computers all the time to fix various problems such as transmission shift points and the like. The only reflashing I've heard of on an SRT-4 is exactly what you said. I'm not sure that's what they are talking about still though.
Old Dec 30, 2006 | 12:49 PM
talisman's Avatar
talisman
Strange how this thread went from a tire issue to re-flashing computers. Seems like a new thread is needed and an explanation about what in the world we are talking about.
Old Dec 30, 2006 | 03:20 PM
Burnnout's Avatar
Burnnout
Haha... I hear ya talisman, np.
