Short Ram intake
Old Dec 25, 2006 | 02:03 PM
Kartman38's Avatar
Kartman38
Default Short Ram intake
i just got a short ram intake.. i was wondering what I should do with the vent that goes to the stock intake box...?? and do i need to have it tuned, like possibly the fuel/ air mix???
Old Dec 26, 2006 | 09:03 AM
talisman's Avatar
talisman
Default RE: Short Ram intake
What kind of CAI did you buy ?
Just install a breather filter on the hose from the end of the valve cover that used to hook to the air box.
You got your OCC and have it hooked up ?
Old Dec 26, 2006 | 09:48 AM
redevil's Avatar
redevil
I don't think you need to tune anything
Old Dec 26, 2006 | 01:22 PM
Kartman38's Avatar
Kartman38
I got the AEM.. and i do have a CC hookep up from my pcv valve to the intake manifold.. but wouldnt oil blow through the breather if I put it on the valve cover??
Old Dec 26, 2006 | 07:14 PM
Plan B's Avatar
Plan B
Unlike the pcv side, the side the breather goes on does not blow any measurable amount of oil. I've had mine on for about 20k and all there is is a slight oil film...
Old Dec 26, 2006 | 09:39 PM
Kartman38's Avatar
Kartman38
so its ok to have the just a breather and to plug the intake?? and did u tune urs after the new intake was on?
Old Dec 26, 2006 | 09:58 PM
talisman's Avatar
talisman
Just hook a breather filter on the hose coming from the valve cover. You can disconnect the battery ground for 10 minutes to let the ecu re-learn the new setup if you want but it's probably not necessary. That is the only tuning needed. Disconnect the battery ground for 10 minutes.
Old Dec 26, 2006 | 10:19 PM
Kartman38's Avatar
Kartman38
thanks.. is there anything else different i should know before or for putting the new intake on?
Old Dec 27, 2006 | 08:16 AM
talisman's Avatar
talisman
Have fun, enjoy the sound, don't get any tickets and drive safe.
