Oil Change What kind?
Old Jan 20, 2007 | 05:17 PM
BLKSRT4's Avatar
BLKSRT4
Default Oil Change What kind?
Yeah so i just changed my oil. And is there really any difference between Mobile 1 And Royal Purple? does it really matter
Old Jan 20, 2007 | 07:12 PM
PSI Chick's Avatar
PSI Chick
Default RE: Oil Change What kind?
not really
Old Jan 22, 2007 | 12:28 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Royal Purple uses a different chemistry than most. They are one of only a handful of marketers using Moly in their oil. Moly is a solid, specifically banned by Cummins, due to excessive valve train wear.
Dusty
Old Jan 22, 2007 | 04:11 AM
BLKSRT4's Avatar
BLKSRT4
so that makes it good or bad?
Old Jan 22, 2007 | 09:24 AM
talisman's Avatar
talisman
If a manufacturer bans a certain type of oil they do it because they feel it could cause engine problems in their engines, so, that's bad. I'd stay with Mobil 1, Pennzoil, Castrol or Valvoline if that is true about Royal Purple.
Old Jan 23, 2007 | 01:57 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
i use castrol full synthetic in my srt
Old Apr 8, 2007 | 01:23 AM
ewetho's Avatar
ewetho
Over at the BiTOG while Mobil1 is not as popular as it once was, Royal Purple is king of hit and miss for good used oil analysis. I personally use Amsoil but for what you listed I would recommend the Mobil1 without hesitation. Unless you do Long Oil Drains stick with regular Mobil1 not EP as the extras will not help protect your engine in the short term (less than 5000 miles) so it would just be a waste of money with a possible small performance loss in the oil.
Old Apr 8, 2007 | 02:02 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yup, in 3 years, no leaks, no oil burning, just the normal oil blow by caught by the oil catch can.....Mobil-1 at Wally World is the best (and least costly) way to go...........
Dusty
