installin a blow off valve
Old Aug 13, 2004 | 01:12 AM
  #21
Rice Burner's Avatar
Rice Burner
Default RE: installin a blow off valve
ya after i got it on, i went and drove threw down town and everybodys head just turned!!!
  #22
Wheat_Burner's Avatar
Wheat_Burner
Hold on... I don't think you guys understand.
You step on the gas, the boost gauge goes uo. If you only step on the gas a little, the boost gauge stays on the vacuum side below zero. When you let off gas, does it still blow off?
Old Aug 13, 2004 | 01:14 AM
  #23
Gargoile's Avatar
Gargoile
ORIGINAL: Wheat_Burner
YES I can make it blow at -5 psi
Old Aug 13, 2004 | 01:25 AM
  #24
Wheat_Burner
ORIGINAL: Gargoile
OK...mine seems to blow off after only -10. I was just under the impression that it would only blow off after higher boost. My misunderstanding.
After half a day I can already see how people can get tired of it.
Thanks.
Old Aug 13, 2004 | 01:27 AM
  #25
Gargoile's Avatar
Gargoile
I can get it at -9 or so, but then I never get tired of it...
Old Aug 13, 2004 | 01:34 AM
  #26
Wheat_Burner
Thanks again, Gargoile.
Nice rims.
Old Aug 13, 2004 | 02:03 AM
  #27
dustyloins's Avatar
dustyloins
Hall of Fame Member
It's good for waking up dozing/cellphone/stupid/talking/ignorant/simply idiot drivers...
Old Aug 13, 2004 | 02:12 AM
  #28
Rice Burner
ya it is loud enough to wake thos kind of people up!!!
Old Aug 13, 2004 | 07:59 AM
  #29
71RoadRunner's Avatar
71RoadRunner
Mine will only blow off from around -3 and up. It also depends on what gear I'm in as to how low pressure it will blow off and how long and loud it can/will be. In first gear it is more reluctant to blow off and it is also not as loud or long as the other gears.
Old Aug 13, 2004 | 12:16 PM
  #30
Wheat_Burner
Thanks, RR. I was also told that either S1 or S2 will change the way mine blows off. I guess time will tell.
I was just expecting it to blow off only after really boosting it.
