what size tire can i use ?
Old Mar 4, 2007 | 10:36 PM
silverblacksrt4's Avatar
silverblacksrt4
Default RE: what size tire can i use ?
well u can use 235 with 18inch tires but u need to have a 35 offset.. i know that i can run 225 tires on stock rims..
Old Mar 5, 2007 | 02:44 AM
silverblacksrt4
you go to www.tirerack.com and they say that you can run 225/45/17 on stock rims so i trust that website!
Old Mar 5, 2007 | 03:43 AM
PSI Chick's Avatar
PSI Chick
you CANNOT run a 225 on the stock rim safely, i really don't care what tirerack says. ask anyone who knows about tires and a 225 is way too big for a 6" rim. it creates a lot of sidewall flex and increases the chances of the tire seperating from the rim dramatically. a 215 is the widest that you should go on the stock rims, you really need a 7" rim for a 225 series.
Old Mar 5, 2007 | 05:38 AM
Aceburner's Avatar
Aceburner
So 18's are safe to run 225 on stock right, and 235's need a 35 offset. Thewheel I was looking at will be 18X7.5 on a 225/40/18 tire. They dont offer 235 anyway so I guess I'm good.
