Boost Leak Test prob?
Old Jan 28, 2007 | 03:45 AM
jmsrt4's Avatar
jmsrt4
Default Boost Leak Test prob?
Ok guys be easy on me. I really am new to this. I built my leak tester. I removed the intake pipe and hooked up my tester to the turbo. I connect my compressor to the quick connect. BUT, here were the teasing begins. I the car supposed to be on or off. When its on I can hear the air coming out the cable disconnected from the intake tube. If the car is on, It dies on me. It sounds like its choking, then dies. Like I said GO EASY! What do I do?
Old Jan 28, 2007 | 09:09 AM
redevil's Avatar
redevil
Default RE: Boost Leak Test prob?
lol.....bro your car sucks air through the intake right???then that air goes through the turbo right!?? well if you shut that hole then no air comes in the motor and it shuts down.It's the same as non-turbo cars, you put your hand in the throttle body and it dies.Look don't turn the car on, and run the compressor at 25 psi.ok let me be more specific.Turn the compressor on, let it fill up to 25 PSI and then shut it off.Hook your leak tester to the turbo and then hook up the compressor line to the tester, a rush of air should go through andcome out through the boost leak.I hope this helps....and don't worry about it we've all been there, and done the same mistakes...good luck
Old Jan 28, 2007 | 07:13 PM
PSI Chick's Avatar
PSI Chick
dono't forget to plug the lines coming out of the intake and tb(if necessary).
car should be OFF to answer your question.
