fabricated gauge pods in stock location
Old Feb 13, 2007 | 05:30 PM
Aceburner's Avatar
Aceburner
Default RE: fabricated gauge pods in stock location
What work is needed to mount the gauges in the dash like that. I like that idea.
Old Feb 13, 2007 | 06:54 PM
motorboy1's Avatar
motorboy1
Its the putting holes in the dashpad thingI could bring myself to do. Other then thatI think they mount just like the factory boost gauge 2screws
Old Feb 14, 2007 | 05:04 AM
silverblacksrt4's Avatar
silverblacksrt4
i thought about volts.. thanks.
Old Feb 14, 2007 | 05:58 PM
04blksrt's Avatar
04blksrt
i dont know about yall, but i absolutely hated trying to change out my factory boost gauge. theres no way im going to put 2 more pods in the exact same spot!
Old Feb 14, 2007 | 06:49 PM
PSI Chick's Avatar
PSI Chick
ORIGINAL: motorboy1
it's a little more than just making two holes. you actually have to trim the underside of the dash for the pods to fit in.
Old Mar 5, 2007 | 08:57 PM
SRTeasy's Avatar
SRTeasy
The Pod picturedwas the prototype. I threw in what gauges I had sitting around and snapped the pics, they are non-operational. This is also on the FAQ's section of my site.
Also, aside from what goes along with installing new gauges, cutting two small holes (half ovals, approx. 1.5x2")on the underside of the dash pad is all that needs to be done. Some have even (not recommended) shaved the back of the actual gauge.detailed, pictured instructions are sent with each pod...
I would recommend Boost, A/F, and Oil pressure gauges to fill your pods...
Hope this cleared some things up..
SRTeasy
Old Mar 6, 2007 | 01:34 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
^ill be going this route when i decide to put an a/f gauge in. it looks so much cleaner than the pillar gauges.
Old Mar 6, 2007 | 09:33 AM
Kristjan SRT4's Avatar
Kristjan SRT4
I have a volt meter in my turbotimer so no need for that. I would preder to have my gauges like in the picture then on my left next to the window. I was thinkin of getting a boost controller so no need to get another boost gauge. So all I would need is a Oil temperture gauge. I think that's the best thing for me.
Old Mar 6, 2007 | 05:11 PM
redevil's Avatar
redevil
how bout a/f? you'll deff. need one of those
Old Mar 6, 2007 | 07:22 PM
Plan B's Avatar
Plan B
ORIGINAL: redevil
Word.
I like thegauge pillar myself, little more 'show'.
