300 is a intake or something small like that...my car stock normally ran around 15psi...so 2 psi isnt really worth it..i could prolly be better off getting a qtp or intake or somthing...dont you think?
no i don't. an intake or a fmic isn't going to help you if it turns out that you're running too lean and you blow your rings. a wideband is something that EVERYONE that changes their boost levels should have. better to spend the money and know what's going on in your engine then blow it. and 2psi is a lot, it's the limit of the stock fuel system....
Modern Performance has the AEM UEGO for $280 shipped, which is only $5 more than the group buy on the other forum. Just orderded mine last Friday and it will be here this Friday.....
no guyes..i do it right...what i meant is.. leave the psi levels stock...take the waste gate off and put the stock one back on..and use the 300 for somthing else..sorry i wasnt clear.
