Stage 1 Fuel Question
Old Feb 19, 2007 | 08:31 PM
WASRT4's Avatar
WASRT4
Default Stage 1 Fuel Question
I have 16psi holdingtill redline now with a stage 1 pcm. i was wondering if the pcm will automatically adjust the fuel? if so what is theoptimal psi setting i should pic? im guessing right where im at 16-17?
if that question makes any sense.
Old Feb 20, 2007 | 07:32 PM
NYYDYNASTY's Avatar
NYYDYNASTY
Default RE: Stage 1 Fuel Question
as long as you didnt take fuel control away from the PCM (such as installing a wga and mbc). then yes, your PCM will control fuel. The highest it can support is around 17 psi.
Old Feb 20, 2007 | 10:53 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
16 -17 is where I've been since I put mine on.
Dusty
Old Feb 20, 2007 | 11:02 PM
NYYDYNASTY's Avatar
NYYDYNASTY
thats fine.
Old Feb 21, 2007 | 01:09 AM
WASRT4's Avatar
WASRT4
dusty did it make a difference? btw - iv been watchin the conversation on the thread about the wga. if all i have is a stage 1- and stage 2 wga and i have it set for 16-17psi. will i have ptb?
Old Feb 21, 2007 | 03:34 AM
NYYDYNASTY's Avatar
NYYDYNASTY
you will have ptb on any stock srt with an aftermarket wga
lol
it just comes with the territory of aftermarket wga's and small turbo's. I mean, look at PSI Chick's car. She's got the stage 3 turbo with the AGP stage 3 wga, and she's got a little ptb. Its not nearly as bad as other people with the stock turbo, but she's still got it.
Old Feb 21, 2007 | 03:47 AM
WASRT4's Avatar
WASRT4
basicly, is everything ok they way i have it setup? s1 with stage 2 wga? @ 16-17psi?
Old Feb 21, 2007 | 03:53 AM
NYYDYNASTY's Avatar
NYYDYNASTY
yes thats fine. If you dont have a wideband, definitely get one. It will tell you if your supplying enough fuel to support the boost.
Old Feb 21, 2007 | 05:24 AM
WASRT4's Avatar
WASRT4
how much are those?
Old Feb 21, 2007 | 05:51 AM
NYYDYNASTY's Avatar
NYYDYNASTY
a wideband isnt cheap. i think they normally cost over $300. but if you search srtforums, you might be able to find one a little cheaper.
