cai
Old Mar 6, 2007 | 07:45 PM
  #21
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: cai
only problem i have heard with the K&N typhoon is the rubber joint that connects it, as it has been said that it can 'suck' inwards on the sides of the joint. if you look at it youll see what i mean
Old Mar 7, 2007 | 01:33 PM
  #22
silverblacksrt4's Avatar
silverblacksrt4
Default RE: cai
well i think that since no body has the mopar cold air that i should get the mopar cai.. also colder air i think does increase boost..
Old Mar 7, 2007 | 01:48 PM
  #23
redevil's Avatar
redevil
Default RE: cai
well I got the typhoon and yes...it sucks inward...that why I wanna get rid of it.Looking forward to an AEM cai
Old Mar 7, 2007 | 04:31 PM
  #24
flamingpinhead
Section Moderator
Default RE: cai
if i were to get a new intake, i would probably get the mopar cai. then just thrown the typhoon on for crappy weather season
Old Mar 7, 2007 | 05:23 PM
  #25
Burnnout's Avatar
Burnnout
Default RE: cai
Cold Air = Less Boost [sm=deadhorse.gif]
Old Mar 7, 2007 | 05:36 PM
  #26
flamingpinhead
Section Moderator
Default RE: cai
^hmm, are you talking about cold air being more dense and therefore containing more O^2 per in^3
Old Mar 7, 2007 | 07:39 PM
  #27
Plan B's Avatar
Plan B
Default RE: cai
ORIGINAL: Burnnout
Thank you, I've been trying to say that the whole time!
Isn't the Mopar CAI practically an AEM CAI with another $100 or so added to the price?
Old Mar 7, 2007 | 08:11 PM
  #28
silverblacksrt4
Default RE: cai
WOW flaming!!!!!!!! we agree on the MOPAR!
Old Mar 7, 2007 | 09:55 PM
  #29
Burnnout's Avatar
Burnnout
Default RE: cai
Cold air is more dense, therefore you don't need as much boost to make the same amount of power... the ecu compensates.
Old Mar 8, 2007 | 04:48 AM
  #30
71RoadRunner's Avatar
71RoadRunner
Default RE: cai
True.
If the joint is sucking partially shut then it's not receiving the full amount of air that it should and this could be the reason for an increase in boost, it's compensating for the reduction in air flow by increasing the boost.
If you already have the Typhoon CAI why replace it with another when all you need to do is replace the thin rubber elbow. I simply bought a mandrel bent 90 degree stainless steel pipe to solve the possible chance of the hose collapsing, I still need to cut it down and install it though. I always had the thought in the back of my mind that the thin elbow could or would suck partially shut during peak boost on the Typhoon when I first got mine and saw that weak link. I would just like to know why they didn't use the same material as what it has to connect the two pipe sections together, it's firm and far thicker which would eliminate any chances of the suck shut scenario.
