secrets
Replace the SRT-4 badge with the NEON badge, take off the spoiler and have fun!!![sm=yeahsmile.gif]
Seriously, there isn't much you can do for nothing, some inexpensive additions that help are motor mount inserts and a good used short throw shifter. Some people will tell you about the wga spring mod, map clamps and other "trick" mods but I would not recommend that because you can really damage your engine that way.
um i did a fmic mm and turboback and that made me get a 13.2 on street tires. now i have a 50 trim from agp. i am waiting for my wideband and fuel controller right now so i cant hert my motor. and you can hert your motor like the other guy said but then you can if your smart about it. meaning get a wideband, dont over boost without the right mods to go with it. but you said you wanted cheap right? well go with a agp wga for 150.00 and set it to peak at 17 psi and to hold 13 14 psi and you will be happy with that.
