Dakota 05 Trailer Brake Harness Codes
Just picked up a 05 Dakota and i need to know what the trailer brake codes for the factory supplied harness that plugs in under the dash are.
The Dodge plug has:
Green w Black stripe, Blue w White Stripe, White w Red stripe, Solid Blue (thicker Wire)
I need to connect the brake controller to this harness.
Thanks in advance.
Roger Kasler
The Dodge plug has:
Thanks in advance.
Roger Kasler
RE: Dakota 05 Trailer Brake Harness Codes
to connect a trailer brake controller in your truck there is a totaly different harness that needs to be hung. The harness you have is only a flat 4 prong plug. what your looking for is a round 7 pin plug that will have to be fabricated and installed
