Transmission Anti-drainback Valve
Old Dec 16, 2011 | 12:46 PM
mopareg's Avatar
mopareg
Default Transmission Anti-drainback Valve
Does anyone know of a direct bolt in part made to replace this valve when removing it?
Old Dec 16, 2011 | 12:57 PM
vpnavy's Avatar
vpnavy
Welcome Aboard mopareg! You probably would get a quicker response if you let us know what type of ride (i.e., RAM, Caravan, Neon, etc.) you are talking about.
Old Dec 16, 2011 | 05:20 PM
mopareg's Avatar
mopareg
Sorry, I have a 2000 Ram Quad Cab 4x4 w/Off-road Pkg. I want to pull this Valve before it causes any problems, but would like a direct bolt in replacement part.
Old Dec 17, 2011 | 01:46 AM
vpnavy's Avatar
vpnavy
Stay tuned mopareg - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Ram for stuff related to your ride.
Old Dec 18, 2011 | 11:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
That drain back valve is there for a reason. I would just replace the drain back valve and steel line. Thats because the only way you can replace the valve is by replacing the line too.
Old Dec 19, 2011 | 08:27 AM
mopareg's Avatar
mopareg
Thanks, but believe I will replace it before I end up with an $1800 rebuild fee!
Old Dec 19, 2011 | 08:31 AM
mopareg's Avatar
mopareg
Angry
What happened to all the other posts with alternative fixes????????????
Old Dec 19, 2011 | 02:17 PM
master tech
I believe you will need to check with a older post in the 2nd Gen Ram section. That was about two years ago?
