Newb with a question
Old Feb 25, 2012 | 11:14 AM
Geo1963's Avatar
Geo1963
Question Newb with a question
Hi guys! Geo1963 here! I have a 2004 Ram 1500 5.7 Hemi. Having a problem starting, coming up with a p0700 code. any takers?
Old Feb 26, 2012 | 12:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
P0700 code is a transmission code thats in the PCM, I would need to know the other stored or active codes in the TCM section of the PCM. You have either the 45RFE or 545RFE transmission.
Old Feb 26, 2012 | 10:28 AM
Geo1963's Avatar
Geo1963
How can I tell witch granny I have, and how can I read the other codes, is there a plug in directly to the transmission?
Old Feb 26, 2012 | 05:27 PM
master tech
They are both the same transmission box, one is a 4 speed and the other is a 5speed.
Old Feb 28, 2012 | 08:52 PM
Dudemanbrother's Avatar
Dudemanbrother
I don't think he's asking which tranny you have, You have a 45, but depending on if the truck has had the service update it could've been flashed to use the 2nd OD, and making it a 5-45. He wants to know the codes from the TCM that "talk" to the PCM. What are the other stored codes on your OBD2 scanner? Those codes will narrow down what's wrong.
