Headlight not working on 2009 RAM
Old Mar 26, 2012 | 02:06 PM
rcsw's Avatar
rcsw
Default Headlight not working on 2009 RAM
I have an 09 RAM. I noticed that my right headlight was out and replaced the bulb in the main headlamp and the bright headlamp. That did not fix the problem. The light still goes out, but comes back on when I hit the headlamp. It will turn on and off intermittently when I turn the brights on and off. Does anyone know what this could be?
Old Mar 26, 2012 | 10:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Did you check the fuses? And if you are still covered under warranty, I would have the dealer look at the problem.
Old Apr 8, 2012 | 05:24 PM
rcsw's Avatar
rcsw
Default solution
The problem was that there was a bent pin in the connector.
Old Apr 9, 2012 | 12:33 AM
master tech
Thanks for the update. Good job!
