Please help!!!
Old Aug 7, 2012 | 07:53 PM
97caravansport's Avatar
97caravansport
Exclamation Please help!!!
Hi my family is stranded in another state right now. On the way to where they were going there 1997 dodge caravan sport 3.3 just died and wouldn't start back up. There have been dash lights on the air bag and service engine, the codes that were pulled was a small and large evap system leak. They just put a new pump in the van, the pump is working just not getting to the engine. And the lines look okay and there's not a gas leak could anyone please help me to get there car going sure they can come home please????
Old Aug 8, 2012 | 11:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Sorry to hear the van is stranded. Does the engine turn over and if it does, do you have spark and the plugs?
Old Sep 16, 2012 | 08:21 PM
pondwater's Avatar
pondwater
probably the ign switch-I found issue with ign wires-red12 += good blue12 + when key turned to on = good yellow 0 power on run or when trying to start = bad - easy cheap fix = momentary push button switch from a steady +12v on one side splice into yellow on the other= WORKS LIKE A CHARM !! of course turn ign to run mode & thun just push button for a second or two-household lite switch would work also if you want to redneck it=just turn on and off quickly !!!!))))))
Old Sep 17, 2012 | 12:22 AM
master tech
I haven't seen another post from the member, so no one knows if the problem was fixed.
Old Sep 17, 2012 | 04:01 PM
pondwater's Avatar
pondwater
Default could be !!
maybe he got it running ??
