Power Window Problem
Old Nov 1, 2013 | 08:34 AM
imoace55's Avatar
imoace55
Default Power Window Problem
2002 dakota quad cab 4.3 V8 lndividual power windows stations not working ONLY drivers PW station operable for all windows /all stopped same time suddenly
Old Nov 1, 2013 | 10:36 AM
Not a switch on the panel to disable the others is there?
Old Nov 1, 2013 | 11:27 AM
Welcome to DF! Yes, did you accidentally press the button to disable the individual switches on the other doors? Been there, done that.....
Old Nov 1, 2013 | 12:40 PM
1ATony's Avatar
1ATony
Former Vendor
If that button doesn't resolve the issue, check the fuse and also the wire harness that runs between the door and body of the vehicle to see if there's a broken or frayed wire in the harness that needs to be replaced.
Hope this helps you out,
Tony
1aauto.com
