Racing Talk Talk about any racing here, whether it be street/strip, NASCAR, F1 etc.
going to the strip on friday
Old Nov 16, 2006 | 05:54 AM
motorider228's Avatar
motorider228
Default going to the strip on friday
I am running my truck for the first time on friday, i have never been to a strip before to run anything, what should i know before hand? How does the tree work? do i just go on green? any info would be great, thanks guys!
Old Nov 16, 2006 | 03:31 PM
freedom's Avatar
freedom
Default RE: going to the strip on friday
after you do your burnout (burnout wont be necessary with street tires, but its damn fun so do it anyway!) you will inch up to the line, light the top set of staging lights, you arent staged until the second set of staging lights is lit.... (remember if the top set goes out but the bottom stays lit you are STILL STAGED!)
Once both cars are staged the tree will start its countdown, you want to go about half way through the third yellow light... dont wait for green.... I usually say "ONE" in my head immediately as the third yellow is lit, and go right after that.... dont worry too much about your reaction time... it doesnt effect your e/t at all... just get comfortable with the process.
Old Nov 16, 2006 | 06:01 PM
motorider228
Thanks for the info freedom. My R/T shouldnt be too bad because I have raced dirtbikes for years so i'm good at jumping once it's time to go but i'm just kinda nervous since i've never done this and I don't want to look like an idiot haha.
Old Nov 16, 2006 | 11:21 PM
vr6_dub's Avatar
vr6_dub
if you have stock/street tires avoid the burn out box..avoid the water. the water will just get in your treads and cause you to spin and get a ****ty 60ft. but like freedom said try to go as soon as the last yellow light is on dont go ahead or you will red light. if you do multiple runs try and see where the "good spots" are. ex: try to see where the track is most sticky. also try to keep your gas under a 1/4 tank of gas for less weight. if you have stock tires drop the rear tires air pressure to keep you from spinning alot.
Old Nov 17, 2006 | 04:11 AM
motorider228
thanks for the info guys! I just noticed the sticky about drag racing. sorry for the idiotic thread.
Old Nov 17, 2006 | 02:41 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
did you mean this:
https://dodgeforum.com/m_502873/tm.htm
Old Nov 17, 2006 | 08:24 PM
motorider228
yes sir
Old Nov 17, 2006 | 09:31 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
hopefully it helps...and if you have any other questions, please feel to fire them up on here, as it will point out things that i didnt cover. [8D]
