Racing Talk Talk about any racing here, whether it be street/strip, NASCAR, F1 etc.
turbo integra
Old Jan 9, 2007 | 12:29 AM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default turbo integra
so my buddy and i just finished up installing a t3/t4 turbo on his 95 (non vtec) integra. its at 11 pounds max boost, and after the tune he should be puttin 250+ hp at the wheels. anyone ever run againsta similar setup car in an SRT-4? we've been argueing recently, i thought an SRT-4 would beat him, he's convinced his weight advantage will give him the win. what do yall think?
Old Jan 9, 2007 | 01:50 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: turbo integra
If he actually has 250 whp then he should be able to beat a stock SRT-4 depending on the drivers.
Old Jan 9, 2007 | 02:22 AM
muddy_blue_dodge
ORIGINAL: 71RoadRunner
we'll know for sure after the tune. we just gotta hook up two hoses that are related to teh PCV system that are being aPITA to reach..... then we're headin out for a dyno tune. its pretty cool.
and yea i think he will have that much.... exact same set ups on other cars are usually about 255-265
Old Jan 9, 2007 | 04:00 AM
71RoadRunner
Has his engine been rebuilt as well, the numbers can vary greatly based on how fresh or worn the engine is. The stock SRT-4's vary from 223 whp to 246 whp. Does his Integra have a limited slip differential and is it auto or standard?
Old Jan 9, 2007 | 11:00 AM
muddy_blue_dodge
not been rebuilt but is a solid engine.... no lsd, standard.
Old Jan 10, 2007 | 02:44 AM
71RoadRunner
The he may have trouble with an '04-'05 SRT-4 since they are the higher numbers at the wheels and have LSD's. He will also have even more problems with the sit and spin of high powered FWD's, unless he can get a hold of the launch problems which all SRT-4 owners are very familiar with.
Old Jan 10, 2007 | 03:30 AM
muddy_blue_dodge
well now we have to put off the tune....... now we have to replace his axles. i dont know a lot about fwd and i forget what its called. axle.... rap? maybe? axle something, that means they need to be replaced.
but thanx for the input
Old Jan 11, 2007 | 06:40 AM
71RoadRunner
It will need it since it will have over double the stock torque, which would twist the stock axles into pieces most likely.
Old Jan 12, 2007 | 05:58 PM
skate_or_die2008's Avatar
skate_or_die2008
Even if your friend dont beat the srt 4 it is still would be nice! Will you post the Dyno results on here when you get back from the tune? I would like so see what it will do.
Old Jan 13, 2007 | 05:41 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
"I live my life a quater mile at a time." - Vin Diesel
