Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
78 Ramcharger won't start need help
Old Feb 5, 2018 | 09:18 AM
brandon spivey's Avatar
brandon spivey
Ah, that's a full time four wheel drive t-case. (NP203?) You always have power going to all four wheels. In "Hi", and "Lo", the transfer case allows differentiation, so, you can use them on any surface. "Lo" is low range. Max speed of about 30mph, and it will sound like your engine wants to blow up. "Loc" means front and rear are locked together, no differentiation there at all, so, use ONLY on low traction surfaces.
i believe it is steel. Any chance of finding a universal? Or other years or models that match?
Old Feb 5, 2018 | 09:58 AM
It's possible, I don't have information on what might swap though....... Maybe from trucks of the same era? (as I think the Ramcharger sits on a truck frame......)
Old Feb 5, 2018 | 07:00 PM
Moparite's Avatar
Moparite
I don't think they are reproduced so you either need to find something else that will work or fix the one you have.
http://www.caswellplating.com/epoxy-...nk-sealer.html
Old Feb 12, 2018 | 03:10 PM
brandon spivey
I'm learning finding parts for these are not easy. I'm going to look at trucks of the same era or look onto fixing it. Good thing is the motor and tranny seem to be all good runs strong and shifts smooth. Need a wiper motor though another part no one seems to have, but I've found wiper motors for trucks from that year probably the same
