Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Transfer case lowering
Old Apr 24, 2019 | 09:34 AM
Drs260's Avatar
Drs260
Default Transfer case lowering
Good morning
I have a 1990 Ramcharger. Just put 4” lift leaf springs on my girl. Now I have to much strain on my u joints. With no success in finding a lowering kit for transfer case.
Mid any one knows where I can buy one or another idea please let me know.
Thanks.
Old Apr 24, 2019 | 10:12 AM
There may be a 'clocking ring' available for you. It rotates the t-case, so the front driveshaft isn't at quite of an extreme angle.
What engine/trans/t-case do you have?
Old Apr 24, 2019 | 10:33 AM
Drs260's Avatar
Drs260
I know I have the 318 but have no idea of the model of transfer case. Is it stamped on it by chance.
Old Apr 24, 2019 | 11:18 AM
Should be a little round tag on the backside of the t-case, that will tell you what it is. (usually red and silver....) Post a pic if you can.
Old Apr 24, 2019 | 11:59 AM
Drs260's Avatar
Drs260
Will try to get that info tomorrow.
Thanks for your help.
Old Apr 24, 2019 | 12:18 PM
u2slow's Avatar
u2slow
Originally Posted by Drs260
Good morning
Thanks.
The stock CV on the front shaft is limiting you. Grind the lumps off the yokes, or switch to a Spicer style (like a 2ndgen Dodge; does more angle).
Edit: My '90 RC has the NP241D tcase.. and the (long) OD auto trans.
If its the rear driveshaft binding, you may be able to shim the pinion up at the leaf springs slightly. It may vibrate if you go too far. Bronco's used a CV shaft in the rear with the tilted pinion. Dodge 7260 yokes aren't known for being able to handle much angle. Spicer 1330/1350 and 1410 series do more.
