Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
fuel sending unit
Old Feb 27, 2023 | 05:35 PM
Sarge2510's Avatar
Sarge2510
Default fuel sending unit
Looking for a fuel sending unit or a how-to fix my existing unit for a 1989 Ramcharger . one of the fuel line nipples on top of unit is broken. I was told that it could not be repaired due to high pressure. If my last post went thru I apologize in advance. Thanks for any help
Old Feb 27, 2023 | 08:00 PM
What size tank? Here is one for the 25 gallon tank....
Old Feb 27, 2023 | 08:52 PM
Sarge2510's Avatar
Sarge2510
mine is the bigger plastic tank, this is not my actual unit but this is what it looks like
Old Feb 27, 2023 | 09:20 PM
Part number I come up with is 4075384, unfortunately, they don't seem to be available anywhere. I might be tempted to find some steel line that will fit inside the existing line, and braze things together..... Either that, or you are going to have to find something to substitute..... Or, go to the 25 gallon tank. Could also try car-part.com, and see if you can find anything thru them.
Old Feb 27, 2023 | 10:06 PM
Sarge2510's Avatar
Sarge2510
not sure if my other reply went thru or not, anyway i will try again. my tank is the larger plastic tank, maybe 32 gallon. This is what my unit looks like, this is not my unit
