torsion bars?
Old Jan 25, 2009 | 10:00 PM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
Default torsion bars?
so was doing some reading in some previous postings over the last few months.
I have some questions
could someone please explain what the torsion bars do?
and advantages and disadvantages to using them?
sounds stupid but..ya just kinda wanted a full input on it
thanks
-scott
Old Jan 25, 2009 | 10:05 PM
manogmin's Avatar
manogmin
the torsion bars are the stock suspension system for the 02-05 4x4's they are adjustable by two 18mm bolts about in the center of the truck on the crossmember under the tranny. you can tighten the bolts to raise the front of the truck, but the two downfalls are that it will stiffen the ride, and if you go too high your shocks will top out over bumps.
Old Jan 25, 2009 | 10:54 PM
lxman1's Avatar
lxman1
Site Moderator
They are a long bar that is twisted to hold up the front suspension. Chrysler has used them forever. All of the 60's and 70's RWD cars had them.
They are used in place of a coil spring.
They are adjustable as far as ride height goes to some extent.
Old Jan 26, 2009 | 12:38 AM
speedy81304's Avatar
speedy81304
there is a torsion bar key that you can change out from ready lift, to get 2" of lift to level the truck out, or do like i did and put a 2" block in the back to give me 2" of lift over stock. dodge got smart and went back to coil springs on the front of the 1/2 tons they should have kept with coil springs as torsion bars cost a good penny to replace when they break.
Old Jan 26, 2009 | 12:56 AM
InfernoRedHemi's Avatar
InfernoRedHemi
thanks
-scott
What year do you have?
Old Jan 26, 2009 | 02:12 AM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah...i broke the bolts for the torsion bars on my 02 dodge i had lol
Old Jan 26, 2009 | 07:53 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
how did you do that? try to turn it without lifting?
Old Jan 26, 2009 | 02:27 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i'm not exactly sure how they broke really.....crawled under there one day and they were broke off....must hit em on somethin when i was out wheelin or somethin lol
Old Jan 26, 2009 | 02:43 PM
nickahern1's Avatar
nickahern1
2 inch blocks in the rear without a level, you would give a crazy hideous raked out look. leveling the front and putting 2 inch blocks in the rear will give the 2inch lift but you will not be level anymore which is the point of a leveling kit or tbar adjustment.
Old Jan 26, 2009 | 10:01 PM
Thatonekidw/theHEMI
i have an 06
is this a no go?
