360 rebuild
Rebuilding the old 5.9 magnum that has about 205,000 miles on it. Heads are off, oil pan removed, Pistons look good still, cylinder walls are in great shape as well, removed camshaft, cam bearings are good, one has a tiny bit of chipped off not too sure if that really will do anything ? Cam lobes are all good. I'd like to upgrade the camshaft, not too sure what to look at. Will lifters and springs need to be upgraded as well? Not too much knowledge on molar engines
Toss the stock heads, and buy new ones. Odessa/Clearwater offer NEW heads, that are better castings, and less prone to cracking. Your old ones are highly likely to be unsalvagable in any event.
Replace all the bearings. You have it this far apart, it would be silly not to. Have the block checked by a machine shop, to see if you need it bored.
You can upgrade the cam, but, keep in mind that is also going to require a custom tune for the engine. Add another 500 bucks for that.
I've used these heads
http://www.ebay.com/itm/NEW-DODGE-JE...VS~SOL&vxp=mtr
most of the other components are from
http://www.hughesengines.com/Index/index.php
See what you like there and go from here
