Headlight issue
Old Aug 1, 2016 | 11:22 AM
RyanWayman's Avatar
RyanWayman
Default Headlight issue
Hey guys. Have a problem on my 95 2500. Headlights randomly flicker on and off while driving. I've replaced the alternator, both headlights, the headlight switch on the dash and on the steering column. Still does it. Any ideas?
Last edited by RyanWayman; Aug 1, 2016 at 11:24 AM. Reason: Needs to go to 2nd Gen
Old Aug 1, 2016 | 05:17 PM
dbbd1's Avatar
dbbd1
Grounding issues? Check and clean your grounds, especially the one under the battery tray.
Old Aug 1, 2016 | 06:50 PM
Moparite's Avatar
Moparite
You replaced the headlight switch but what about the connector? The 2500's and 3500's have more lights to run than a 1500. This subject was talked about in another thread. There was a update for the issue with the 3500's but they seemed to forget about the 2500's. This is what mine(2500) looked like.
Old Aug 2, 2016 | 06:37 AM
RyanWayman's Avatar
RyanWayman
I replaced that as well. Would the positive battery cable having some corrosion on it have anything to do with it?
Old Aug 2, 2016 | 06:53 AM
ramsportrocks's Avatar
ramsportrocks
could be that COMMON lose wire issue in the multi switch
if you have a tilt wheel, try moving the wheel up and down
when it happens and see if they come back on
