Vacuum Leak Behind Dash
Old Feb 11, 2017 | 10:22 AM
dbbd1's Avatar
dbbd1
Beeker knows, he's had his dash all apart.
Old Feb 11, 2017 | 12:38 PM
beeker's Avatar
beeker
Originally Posted by Chunx89
Wow thanks for that input, I was going to start behind there anyway but that definitely helps! Im almost positive it's the hose going through the firewall, I tried pulling any slack out of it to see if I can find a hole and there is no slack what so ever and it's only a good 2 inches out from the firewall. I'm guessing the previous owner pinched the hose while installing the heater core
It's very likely a pinch could occur when reinstalling the dash. Even when taping the hoses back to their original location. I routed my hoses over the top of the air box instead of behind it when reinstalling the dash to avoid any chance of a pinch.
Here's a good look at the rear of the the air box. You can see 2 of the silver can actuators that are mounted to the right of the gas pedal.
And the right actuator(silver can) Green Hose
Old Feb 11, 2017 | 02:44 PM
Chunx89's Avatar
Chunx89
I'm working on the truck now and I can't find the leak, this thing only makes the noise when in gear and accelerating. It's coming from this area it sounds like
Old Feb 11, 2017 | 02:46 PM
Chunx89's Avatar
Chunx89
I checked the blend door actuator and it's not coming from behind there, and it's hard to tell where it's coming from because I can't visually see anything back there and it won't leak unless I'm accelerating in gear
Old Feb 11, 2017 | 03:34 PM
Get a nice bright flashlight. See if you can follow the lines where they go, or, move them GENTLY to someplace you CAN see them.
Might grab a friend, have THEM drive, while you go poking about too....
Old Feb 11, 2017 | 03:47 PM
Chunx89's Avatar
Chunx89
This possibly could be my air sucking noise!
Old Feb 11, 2017 | 04:05 PM
Little dry-rotted there.....
Old Feb 11, 2017 | 04:18 PM
Chunx89's Avatar
Chunx89
I'm second guessing a vacuum leak, wouldn't it leak regardless if the truck is in gear or not? Even if I'm in gear hitting the gas it won't make a noise and I don't hear anything unless I'm actually accelerating, which the noise gets louder as the Rpms raise
Old Feb 11, 2017 | 04:51 PM
Might have to take a look under the cowl, where the wiper mechanism hangs out, and check the lines, and vacuum reservoir found under there.
Old Feb 11, 2017 | 10:24 PM
Chunx89's Avatar
Chunx89
Not celebrating too early but I just got home and stuck a light into the cowl and boom, hose has a hole in it! Hopefully it's not a dead bug lol
