door ajar alarm
Old 02-04-2009, 08:13 PM
drummer1279's Avatar
drummer1279
drummer1279 is offline
Default door ajar alarm
I have a 92 grand caravan SE 3.3. my door ajar alarm keeps going off while I am driving. I have disconnected the driver and passenger side door sensors and it still dings leading me to believe its the sliding door or something else. any input on fixing the problem is appreciated before the dinger drives me insane.
Old 02-04-2009, 11:23 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Its the sliding door ajar switch. This was a common problem back in the early 1990's. Get a new switch and install it. To make the ajustment, just close the door.
Old 08-21-2024, 03:35 PM
Parvez M's Avatar
Parvez M
Parvez M is offline
Default Grand Caravn sliding door Ajar and beeping when going over bumps.
Can angone how do I fix the beeping noise while driving I beleive it is from passenger rear sliding door.
Old Today, 01:56 AM
master tech
Have you replaced the switch? If you don't know which switch is causing the issue. Unplug each one at a time and drive it and see if it beeps. That is if you have two sliding doors. Don't rule out the front door either.
Old Today, 04:25 AM
Parvez M's Avatar
Parvez M
Parvez M is offline
I was told by dealer the switch is part of the lock on the passenger sliding door and it is around $300.00.
Quick Reply: door ajar alarm
