ISO: 94-95 5.9 ecu
ISO: 94-95 5.9 ecu
Making some great progress on my 5.9/518 swap on my 88, still missing a few pieces. The main item im missing not easily available for a reasonable price is an ECU. Looking for a 94-95 only 5.9 magnum. Trans type doesn't matter, that's all being removed from the harness. Both my local u-pull lots charge $39 for one, but don't have any in my year range with the single large connector with the bolt. If you have one laying around, or can get one for similar price for your local u-pull, let me know.
Are you sure you can't use a 5.2 ECU instead? Since you're going bigcube, it'll need to be tweaked ANYWAY.
RwP
P5249546 Engine Controller, 1994–95 5.9L Ram, Automatic
Transmission
Nice to see you poking around here Crazy. You still driving that SAS'd Dakota you built a few years ago?
I drive it ever so often. Right now I'm working on lowering it, it is too tall. So this means redesigning a little bit of the suspension and steering to make work with the new stance. Thanks for noticing.
Please, when you do the suspension changes, share it with the forum. Your past work was always of interest to me, and I'm sure many others as well.
