On that, I don't know...... Would likely have to crawl around with a tape measure, and then compare the two. (either that, or, the stats might be out there on the web somewhere, but, I wouldn't hold my breath on that. It IS rather esoteric info. )
The actual bed dimensions are the same. However I don't know if the mounting nuts will match up well with the frame holes. Also the body lines are pretty different and will look way off.
