poly for leaf springs
Old 09-19-2017, 04:15 PM
93 ragtop's Avatar
93 ragtop
93 ragtop is offline
Default poly for leaf springs
Anyone using the poly bushings in their leaf springs? Just would like their opinion on them.
Got the rear of my truck tore apart. My factory bushings dont look bad (83,000 miles) but being 30 years old, well......
FWIW I have put poly bushings in the front end, ie. control arms, sway bar.
Old 09-19-2017, 04:19 PM
RalphP's Avatar
RalphP
RalphP is offline
Not yet, but I have'em.
Pros: Less likely to fail with age; more consistent ride over the years.
Cons: Passes more of the road vibration through from the springs to the chassis; can squeak with age (and not much age!) due to how poly works.
Recommendation: Try to keep some spray lube handy, and hit them every time you're under the truck, to keep it from sounding like a set of bed springs under some newlyweds on their honeymoon ...
RwP
Old 09-19-2017, 04:24 PM
tbugden's Avatar
tbugden
tbugden is offline
Yeah I got them in mine. No problems but they do squeak a little. Doesn't bother me at all but if you can't deal with your truck making a few miscellaneous noises then it might bother you.
Old 09-19-2017, 06:03 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
You can always coat the mating surfaces with copper anti seize
Old 09-19-2017, 07:14 PM
tbugden's Avatar
tbugden
tbugden is offline
They make this ridiculously sticky grease specific for the poly bushings which I used liberally. But they still started to squeak a little...or perhaps that's something else in the rear end...lol who knows.
Old 09-19-2017, 09:28 PM
robertmee's Avatar
robertmee
robertmee is offline
Same as Ralph...have them but not installed them yet. No squeaking yet.
Old 09-20-2017, 11:06 AM
93 ragtop's Avatar
93 ragtop
appreciate everyone's input!! I ordered a set this morning.
