ABS/ESP BAS/Traction Control Lights On
Old 09-21-2017, 01:59 AM
Jhass's Avatar
Jhass
Jhass is offline
Default ABS/ESP BAS/Traction Control Lights On
So these lights popped up recently. Truck has been running like garbage. Sounds terrible like bad rocker noise since these lights came on (which I found was quite odd, although these lights temporary went out one day and truck sounded fine again). The cruise control don't work either.
So I hooked up the old computer and found these
U1417 - implausible left wheel distance signal received
C1020 - left rear wheel speed circuit sensor
C1027 - left rear wheel speed sensor signal erratic performance
I'm guessing from these codes that my left rear abs sensor is toast? Should I just replace the sensor or also the harness and wiring too?
Is there any chance it may be the sensor located on the diff?
Any suggestions appreciated. Cheers
Old 09-21-2017, 09:41 AM
How many sensors do you have back there? Is there one at each wheel, AND on top of the diff??
Old 09-21-2017, 10:11 AM
Jhass's Avatar
Jhass
Jhass is offline
That's correct.
Old 09-21-2017, 10:51 AM
Then, if every code relates to the left rear speed sensor, replacing that would be a good first step.
