Fitting 20x12's the right way?
Old 09-22-2017, 11:13 AM
ATLKillian's Avatar
ATLKillian
ATLKillian is offline
Default Fitting 20x12's the right way?
Morning y'all,
I'm back with another question about my 94 1500. I really like the look of 20x12 wheels. I found a set I like for a good price. They are 20x12 with a -51mm offset which I know will be hard to accommodate on my truck. I would like to wrap them in a 33" tire. My truck is a 2WD 1500 at stock ride height. What steps would I have to take to get these wheels to fit properly (or somewhat properly lol)? Longer control arms? Coil spacers?
Thanks!
Old 09-22-2017, 02:13 PM
That should be right about 4" backspacing...... which is about right. Being that wide though, I would expect 33's to make contact with the outer wheel opening when you turn.......
Don't think you can do 3" spacers without putting a lot of strain on the balljoints on a 4x2 though... I think 2.5 is the max, without doing other work as well. Probably still have to do some fender carving to clear the tires.
Would look pretty cool though.
Best I can offer is, mount up the fronts, set the truck back down, turn the wheels lock to lock, and see what you get.
