mopar performance computer 1993
Old 10-07-2017, 12:03 AM
93duhkota's Avatar
93duhkota
93duhkota is offline
Default mopar performance computer 1993
ive been doing some searching and keep finding claims that the mopar performance computer P5249516 increases torque and horsepower. i was wondering if anybody has ever dyno tested it to see if it actually does. ive had one in my truck since the day i got it and have been curious. it seems pretty peppy. the only things that have been done to it is a magnaflow muffler on the 3" factory exhaust and the pcm.
Old 10-07-2017, 09:40 AM
Moparite's Avatar
Moparite
Moparite is offline
All the mopar performance computers are programed for performance over the stock units.
Old 10-07-2017, 10:35 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
The Mopar Performance PCM's states that they require high octane fuel, 93+ or so. The PCM advances the timing when needed, the high octane is needed to prevent pre-detention (pinging). I do have the Mopar Performance PCM for my 5.9 Magnum, and I do run regular fuel with no pinging.
Old 10-10-2017, 11:31 AM
ragged89's Avatar
ragged89
ragged89 is offline
Years ago one of the car magazines did a dyno test comparing the stock PCM to the performance PCM, on a 5.2L I believe. I may have that somewhere, if so, I'll post what I have. As I recall, there was a small HP increase, and a more substancial torque increase. I run one on my '92 5 speed, and it does wake that 5.2L up noticeably.
Old 01-17-2018, 04:53 PM
speedfreak955's Avatar
speedfreak955
speedfreak955 is offline
Hello everyone!!! I've recently purchased a 1994 dakota 5.2/46rh extended cab. Will the computer off the 92/93 work??
If not is there a ram unit that will?
Old 01-18-2018, 12:58 AM
RalphP's Avatar
RalphP
RalphP is offline
92/93 computers will expect smaller flow rate injectors, and EGR being present.
I'd try to find a 94/95 computer.
What part of the universe are you in?
(THAT said - I think the RAM unit will, but don't know for sure; I'd compare part numbers).
Oh, and another question - why are you looking for a computer for it?
RwP
Old 01-18-2018, 05:42 AM
speedfreak955
Thanks RalphP,
I'm In West Georgia
The comp is fine on mine, I was looking at future performance mods.
The truck will not need emissions after this year so I figured I'd have some fun with it.
Old 01-18-2018, 10:32 AM
Toby Warford's Avatar
Toby Warford
Toby Warford is offline
Originally Posted by speedfreak955
Thanks RalphP,
I'm In West Georgia
if you want performance you'll want to get a 96 harness and computer and switch to obd2. Them contact Ryan Hogan aka Flyin Ryan performance and let him have his hand at it. He is the best mopar tuner there is hands down for a magnum engine. You can use a ram computer just find so long as the parameters are right for your fuel injectors. I have a ram computer in my dakota for the 5.9 I just had swaped in.
Old 01-18-2018, 05:56 PM
RalphP's Avatar
RalphP
RalphP is offline
This.
However, that's a bit more than just "swap the ECU" out; before you jump into that, grab a copy of the 1996 FSM (from the FAQ here) and find a copy of the FSM for your current truck to cross verify all the wiring differences.
(There's enough to my 1988 that I'd do MUCH better grabbing a 1996 donor that runs. At which point, the question becomes, why not just run the 1996 and mothball the 1988? That's a good question, and one reason why I haven't jumped on to that yet *grins* )
RwP
Old 01-18-2018, 06:45 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
This is an interesting discussion.
This may be slightly off topic but Ralph you said the 93/92 have smaller injectors. If I got a 93 computer and put smaller injectors in would that improve mileage? Or just put smaller injectors in with the OE PCM?
Edit- I currently have reman injectors from here http://www.fuelinjector.citymaker.co...25/4735745.htm
