97 ram 2500 5.9 gas motor
Old 01-19-2018, 10:53 PM
john mccomas's Avatar
john mccomas
john mccomas is offline
Default 97 ram 2500 5.9 gas motor
I got a 97 ram 5.9 gas engine. I want to
change the efi to a carb.
Anybody done this? Need to be able to bolt
the accessories back up to the carb intake.
Will i need to change the distrlbuter?
Don
Old 01-19-2018, 11:07 PM
jkeaton is offline
Moved to the correct section.
Old 01-20-2018, 08:54 AM
Why would you want to do that? Do you have an automatic trans? If you do, then you are going to need to figure out a way to run that as well, as it is all electronic too.
Old 01-20-2018, 01:50 PM
Moparite's Avatar
Moparite
Moparite is offline
Can be done but the pcm runs everything so you will also need to take that into consideration. Yes you will need to change the "distrlbuter".
Quick Reply: 97 ram 2500 5.9 gas motor
