Transmission swap
Old 01-21-2018, 11:11 PM
David Middleton's Avatar
David Middleton
David Middleton is offline
Default Transmission swap
Will the transmission from a 93 Dodge Dakota 4wd fit in a 95 Dodge Dakota eat 4wd?
Old 01-21-2018, 11:18 PM
RalphP's Avatar
RalphP
RalphP is offline
Yes. Now, if they're the same transmission (42RH, 46RH, or NV1500/2500) then it's a lot easier.
RwP
Old 01-21-2018, 11:24 PM
David Middleton
RwP
So the cab size doesn't matter?
Old 01-21-2018, 11:28 PM
David Middleton
I forgot to ask if the engine size matters?
Old 01-21-2018, 11:47 PM
RalphP's Avatar
RalphP
RalphP is offline
It might; which motor to which motor.
As to cab, why should it? The wheelbase matters for the driveshafts; but the motor/transmission combo is the same, if it's the same number of drive wheels.
RwP
Old 01-21-2018, 11:49 PM
David Middleton
RwP
A 3.9 v6 - a 5.2 v8
Old 01-21-2018, 11:55 PM
RalphP's Avatar
RalphP
RalphP is offline
See my note about "42RH/46RH"? I mean if the old and new transmissions are both 42RHs from 4WD vehicles, no problem. If, however, one is a 42RH (from the 3.9) and the other is a 46RH (from the 5.2), you may need a different drive shaft.
You'll also need to use the right torque converter.
(The TCs might change due to the transmission input shaft being different - or may not. Time to ask a transmission shop.)\
RwP
Old 01-21-2018, 11:57 PM
David Middleton
RwP
Thank you very much, I'm trying to get all the information I can get to start with and you've been a big help.
Old 01-22-2018, 09:36 PM
robertmee's Avatar
robertmee
robertmee is offline
A 42rh (A500) won't last long behind a v8. Wasn't sure from your post which way you're going. The 46rh (A518) is what you want for your v8. The cross member mount and bell housing are the same. However the tail shaft on the A518 is .5 inches longer.
Old 01-28-2018, 02:07 PM
volaredon's Avatar
volaredon
volaredon is offline
WHAT!?! no it isn't. They use the SAME tail housing from a 42/44 RH (A500) as they do on the 46RH (A518) the trannys are the same overall length either way. Dipstick and tube, converter, and inspection plate are all that is different between them, AS FAR AS SWAPPING ONE WHOLE UNIT IN PLACE OF THE OTHER is concerned..... pan is different, and internals are bigger on the 518 than the innards of the 500....as is the front half of the trans case. Don't quote me on this next part but I think you can swap valve bodies between them as well......
as far as how long a 42 will last behind a V8..... they CAN last if you don't drive like a bat out of He11.... the 42 and 44 are basically the same trans, the 44 just has more clutch discs within the clutch packs inside the trans as compared to the 42.
Quick Reply: Transmission swap
