01 NO BUS no spark no fuel won't start
Old 04-22-2018, 12:15 PM
Jessika Whitekiller Morris's Avatar
Jessika Whitekiller Morris is offline
Default 01 NO BUS no spark no fuel won't start
Issue started intermittently would die when coasting or coming to stop. Pulling battery cable for about 30 seconds would fix for a while but then wouldn't anymore. Will crank but wont start. Please help. Been down a month and only vehicle I have
Old 04-22-2018, 12:30 PM
Need to find out what's missing, spark, or fuel. Spark is easy to check for, do that first.
Old 04-22-2018, 12:44 PM
I don't have either
Old 04-22-2018, 01:03 PM
Start disconnecting sensors one at a time, until you get your odometer back.
Old 04-23-2018, 02:56 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
If the cluster says NO BUS then that usually indicates wiring problem or PCM is bad.
Quick Reply: 01 NO BUS no spark no fuel won't start
