Brake Calipers - 93' Dakota
Old 09-12-2018, 08:23 PM
bronze's Avatar
bronze
bronze is offline
Default Brake Calipers - 93' Dakota
The front brake calipers (backs are drums) are original on my 93' Dakota. I am the original owner and there are 172,000 miles on my truck. I am going to do new pads, cylinders, rotors drums, n hardware in the Spring. Contemplating putting new calipers in too. Doesn't appear very expensive after getting core charge refunded. They seem to be working perfectly fine but if I'm gonna do a complete brake job then I may as well go all the way, right?
Thoughts?
Old 09-12-2018, 09:01 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
I did this when I bought mine, I also added the bearings.
Old 09-13-2018, 01:51 AM
RalphP's Avatar
RalphP
RalphP is offline
Add in all hoses.
I'd also consider painting the new calipers with caliper paint ... but that's me.
(Next ones on my Dakota will be gloss black.)
By "all hoses" I mean the two front AND the rear; at 26 years old, that rubber is starting to fail.
RwP
Old 09-13-2018, 09:33 AM
bronze's Avatar
bronze
bronze is offline
Ralph, are those fabricated lines or are they bulk hose? Do you know off the top of your head?
Old 09-13-2018, 10:27 AM
tbugden's Avatar
tbugden
tbugden is offline
I was just going to rebuild my calipers with a $7 seal kit but it turned out entirely impossible to get the seals to set correctly while pushing the piston in. Looking online it seems that I'm not the only one. I've rebuilt calipers before but these were a different beast. So needless to say I bought new calipers and haven't looked back. Good idea IMO with that many miles.
Old 09-13-2018, 10:29 AM
tbugden's Avatar
tbugden
tbugden is offline
Those are premade hoses with all the fittings and female threads to fasten the hard lines. The rear may also come with the plastic clips for the axle vent hose. You can get them on rockauto.com or any parts store.
Old 09-13-2018, 11:07 AM
bronze's Avatar
bronze
bronze is offline
Hey TB, I looked at Advanced Auto and they don't carry the brake line parts for my Dodge. I haven't looked elsewhere.
I contemplated rebuilding my own calipers but then I looked at the cost of buying them and think this is the way to go for the reason you gave. Buying them is not expensive and I know I wont have to deal with corrosion, fitment, and other issues.
Thanks for your input. UPDATE: Found them on Rock Auto. Thanks again! Recommend a particular brand??
Old 09-13-2018, 09:02 PM
RalphP's Avatar
RalphP
RalphP is offline
Well, I said "hose", not "line".
I like Wagner, Rockauto, ACDelco, and Mopar personally.
RwP
Old 09-14-2018, 07:57 AM
bronze's Avatar
bronze
bronze is offline
RwP
I used the words interchangeably.
Thanks for the help!
Old 09-14-2018, 09:38 AM
RalphP's Avatar
RalphP
RalphP is offline
Line and Hose aren't quite interchangeable; line is the hard copper, hose is the flexible portion.
The point is, you won't find brake LINES preset for our trucks, but you'll find brake HOSES
RwP
Quick Reply: Brake Calipers - 93' Dakota
