temp gauge dont work 95 dakota 2.5
Old 10-13-2018, 09:36 PM
colbyvaughn's Avatar
colbyvaughn
colbyvaughn is offline
Default temp gauge dont work 95 dakota 2.5
I have had the truck for 6 months. When I first got it it didn't have a t stat in.i put one in it. I live in Mississippi. I got burped out.the heat works. A little steam came from the radiator. I wouldn't mind putting a aftermarket gauge.i gotta figure that out first. Is my temperature sensor bad. I got a check engine light.
Old 10-14-2018, 08:14 AM
jkeaton is offline
What is the code from th check engine light? That’s your first clue.
Old 10-14-2018, 10:50 AM
RalphP's Avatar
RalphP
RalphP is offline
1) As JKeaton said, code your truck. It's easy to do with "The Key Dance" - with the key in the igntion, take a deep breath, and turn it on/off/on/off/on within about 5 seconds (that's ON, not START! Like you were turning it ON right before starting the truck ... )
2) You have two temp sensors; does the gauge work? If so, the single wire is working. The two-wire sensor MAY be bad. But the one-wire won't cause a CEL; it's a completely independent system on the 1st gen Dakotas.
3) In the FAQs (specifically FAQ, not FAQ2) in the stickies at the top of the forum postings, you can find the factory service manual as a PDF download (well, a link to it!) DOWNLOAD IT. You NEED that to work on your truck. (Or go buy a copy, your choice, but hey, it won't cost you anything here!)
(We have 95 and 96 FSMs up there; scroll about 1/3 of the way down to 1/2 the way down in the posting, and you'll find the link.)
I'd also get the parts list, so you can hunt up the original part numbers for parts you may need.
RwP
Old 10-14-2018, 10:56 AM
colbyvaughn
Where is the one wire sensor located
Old 10-14-2018, 11:48 AM
colbyvaughn
I figured it out y'all. It was a wire that wasn't hooked up. But I still have little heat
Old 10-14-2018, 12:16 PM
Probably an air pocket in the heater core, or, a blocked core.
Old 10-14-2018, 04:11 PM
RalphP's Avatar
RalphP
RalphP is offline
Could also be a bad thermostat. When you say "little heat", do you mean the temp gauge is low, or that it's about mid range and the air out is still cold?
RwP
Quick Reply: temp gauge dont work 95 dakota 2.5
