2008 nitro shuts off when heater is running
I have a 2008 dodge nitro. I have recently replace 2 oxygen sensors. It is still rough while it is in idle. It kind of has a bouncing feeling. Anyway, when I run my air, everything is fine. It has shut off on me occasionally. But when I run the heat, it shuts off while driving ALOT! Could it be the other 2 sensors needing replaced or a whole separate issue? Also, my wipers are stuck on the on position and will not shut off, and my signal lights will not work at all. If anyone could help me out with ideas please!!! It's so frustrating! Cause my only option at the moment is pulling the fuse when I don't need my wipers and putting it back in when I need them. Thank you!!!!!
