Mystery no start
Mystery no start
Hi all I have a 2001 4.7 off 4x4 Durango with the 45rfe tranny it has had its issues with not starting with no conceivable pattern tonite I stopped a t a buddy's house and when I went to leave no start we tried to jump it no start I tightened the cables no start checked the fuses none blown wiggled wires nothing called home and tried one more time it started but now I have no radio or inside rights no high beam light no turn signals and the security light is on is this an ignition switch or bad ctm. Or bad pcm.
Mystery no start
Ok ok I found and fixed part of my problem it's not the start problem but after when I had no inside lights,high beam indicator and radio. It was the number 1interior light fuse the 1in the funky black fuse holder now everything is back like it should be. I had four the the data link connector was broken apart ,I probably kicked it by mistake getting in or out of the truck I have big feet lol repaired that and found the fuse finally. Go me. Now the no start thing last nite I wiggled the key as I was driving home to get the turn signals working. Now I will pull the key switch and test it to see if it has a short. Will let you guys know the results after thanks for all the help.
