Oil from U joint--1990 Dodge w250 gasoline 5.9L
Old 02-17-2019, 11:31 AM
SteveBarker's Avatar
SteveBarker
SteveBarker is offline
Default Oil from U joint--1990 Dodge w250 gasoline 5.9L
I'm getting oil on U joint, not grease,nor transmission fluid, just where drive shaft connects to Tranny. The seal looks dry, but I just had transmission rebuilt.Could it be an output shaft seal? Thanks for help. Steve
Old 02-17-2019, 11:41 AM
HeyYou is online now
Received 3,210 Likes on 2,961 Posts
Probably. If the seal isn't properly lubed before installation, it'll get smoked pretty quick.....
Old 02-17-2019, 01:08 PM
SteveBarker
Thanks. I didn't know there was oil around "that area". I'll pull the drive shaft. It must be gear oil ? If so, what weight and how or should, I add some when I put it back together? Steve
Old 02-17-2019, 01:26 PM
What transmission?
Old 02-17-2019, 02:41 PM
SteveBarker
1990 dodge w250 5.9 liter fuel injected "Z" in vin number. Cal emissions 3 speed with electric overdrive. Completely rebuilt.Everything new except upholstery. I drive it about once a week
Old 02-17-2019, 02:52 PM
ATF +4 only.
Check trans fluid level, (in neutral, can't check in park) if the level looks good, don't worry about it.
Quick Reply: Oil from U joint--1990 Dodge w250 gasoline 5.9L
