water pump gasket
water pump gasket
I have read conflicting advice whether to use an rtv sealant (or gasket maker) in addition to the formed gasket for the pump. some say that using a sealant will cause leaks and some say that not using a sealant will cause leaks. what say you guys? the internet can give great advice. sometimes it can drive you crazy.
I currently have a leak that "may" be the pump gasket. when I replaced it 10-15,000 miles ago , I did not use a sealant with the gasket.
95 ram 360
95 ram 360
95 ram 360
95 ram 360
This. Makes life much easier. I just put a very thin coat on both sides of the gasket. Helps seal up some of the irregularities you often find on the sealing surfaces.
thanks, in a couple of wks I will start working on it.
First: I will remove the ac compressor, alt and support bracket (WITHOUT disconnecting coolant system).
Then pressure test the system to confirm no topside leaks (bypass hose, thermostat housing, timing cover gasket).
Will let you know what I find.
