PCM needs repair
Old 07-18-2019, 12:03 AM
Viperdave's Avatar
Viperdave
Viperdave is offline
Default PCM needs repair
I need a good company that can repair a 1995 dodge truck gas engine PCM
anybody ever use SIA electronics?? Are they any good?
Old 07-18-2019, 07:40 AM
Received 3,207 Likes on 2,959 Posts
The OBDI fellers are getting harder and harder to find anyone that does anything with them.... There is a company that is a sponsor on the site, but, I don't know if they still do OBDI computers.
Old 07-18-2019, 12:57 PM
tndakman's Avatar
tndakman
tndakman is offline
This company rebuilt my OBD1 MP Part # P5049516 for my 1992 Dakota 5.2. I can't answer for them about rebuilding/replacing your computer but I can give you their website & my SATISFIED review. https://www.autoecu.com/ Good luck!
Old 07-18-2019, 03:14 PM
Viperdave's Avatar
Viperdave
Thanks I will check them out,
as “heyyou” had said, it’s getting harder to find someone that can work with OBD 1 stuff
Old 07-18-2019, 06:36 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Have you considered swapping your PCM with another one with the same part number? I did that a while back with I tried to flash my original PCM with an SCT tuner that ended up bricking my PCM. The replacement PCM was used off another truck and it worked perfectly.
Old 07-20-2019, 01:17 AM
Viperdave's Avatar
Viperdave
Default Update
I went looking for another PCM, well actually I cut my wife loose and she found 2 on EBay
my problem is, this engine is a 1995 360 magnum out of a 1 ton dually truck
i started this project with a regular 1995 360 out of a 3/4 ton truck but the gross vehicle weight for that engine was around 8500 lbs. well that wouldn’t do if I was to smog leagle this beast in California, the gross vehicle weight on my chassis is 10500 lbs so I looked for a 1 ton truck and found one in pic a part, spent 2 days pulling the harness, air pump, and comp.
gross vehicle weight on a 1 ton truck is 10500lbs
the 1 ton truck uses 2 o2 sensors and has dual exhaust back to dual cats with air injection
anybody in 95 looking for a dually work truck wanted the v10 or Cummings diesel so v8 duallys were a lot rarer
i found out that a regular 95 br truck pcm with one o2 will actually run the engine but not well with only 1 o2 sensor
back to to my wife , she found 2 on eBay, same part numbers,
one was was in good shape and she got it for $175.......cool!
what she didn’t tell me until it arrived was she bought the second one also
it had a broken mounting ear and she got it for $39!!! Same part number
ran both of them for a couple of hours and not one problem!!
they both have around 100k for mileage
i have the $39 one in it now
just had both cats installed today so on to installing the air pump and fabricating the air lines back to the cats
viperdave
Quick Reply: PCM needs repair
