help needed to identify part leaking coolant
Old 07-18-2019, 12:48 PM
Trav Dickinson's Avatar
Trav Dickinson
Trav Dickinson is offline
Default help needed to identify part leaking coolant
I have coolant leaking from the threaded metal connector piece of my 2000 dodge durango 4.7 what is this part called please help
Old 07-18-2019, 02:38 PM
sporta's Avatar
sporta
sporta is offline
That's the upper radiator hose connection on the timing cover. Will have to check on mine but don't think its threaded...I'll pop the hood on my '00 in a few and get back to you...
Old 07-18-2019, 04:39 PM
Trav Dickinson
Default ok
That would be greatly appreciated thanks
Old 07-18-2019, 06:14 PM
sporta's Avatar
sporta
sporta is offline
Here you go. You might be able to unscrew it but mine came attached to the timing cover
Old 07-18-2019, 07:18 PM
Trav Dickinson
Default Thanks
I will try to unscrew it and put some pipe dope or teflon on it thanks
Old 07-19-2019, 07:34 AM
Don't over-tighten it, might crack the housing it goes into.... then you have a real problem.
Quick Reply: help needed to identify part leaking coolant
