What's Killing My Alternators?
Folks, I've replaced my battery twice, and then the alternator 3 times in the last two months trying to resolve a dead battery issue, what a hassle! Twice the tow truck guys did a test and said alternator is bad.
I thought it was bad alternators I was buying, but I'm wondering if something ese was killing them, like a wiring issue?? I'm taking it to a real mechanic tomorrow!
96 Ram 1500,
96 Ram 1500,
The tow truck driver likely just put a voltmeter on and determined it's not charging, That doesn't mean the alternator itself is bad, as HeyYou mentioned there is also a voltage regulator that controls the alternator. It is part of the PCM and a control wire runs from the PCM to the alternator. So it could indeed be a failure in the PCM but also simply a wiring issue.
PDC is Power distribution center. The fuse/relay box under the hood.
PCM is powertrain control module. The computer that runs the engine/trans (if you have an automatic)
Voltage regulator for the alternator is built into the PCM. Unfortunately, they are a common failure point. Change the alternator as often as you like, and it still won't charge, as the VR is toast.
