Anyone know where I can find the heater box vacuum line set (4746208)?
I'm trying to find a the heater box vacuum line set (part# 4746208), but it seems to be discontinued. Does anyone know of an aftermarket source for these color coded vacuum lines or if I can find the color coded vacuum lines individually, so I refurbish what I have?
Thanks for the info, however, it shows as the part is discontinued in the part description, but yet they will still let you add it to the cart for purchase. I will call them on Monday @ 800-428-0517 to verify if they do indeed have one laying around.
As a backup plan, if anyone else knows of another place where this part might be available, please let me know..
I did pull the spare HVAC box from a donor truck and I pulled everything attached to it, however, I'd like to replace that vacuum harness as some of the vacuum lines look suspect.
I called the Chrysler Parts Overstock dealership in Lakeland, Florida this afternoon. The part is indeed discontinued and no longer available according to them.
