Check engine light codes help... 98 dodge ram 2500 5.9l gas 4x4
wondering if I could get some pointers on where to start, Ive already got a abs speed sensor ordered but idk what to do about the rest and advice would be welcome... I have a doorman intake manifold gasket set with the plenium gasket kit I need to do I ordered that before I seen the hughes engines fix kit
P0132 O2 Sensor 1/1 Circuit Voltage High
P0138 O2 Sensor 1/2 Circuit Voltage High
Lambda sensor? Well it seems 02's have another name that i have never heard before. The misfire codes are most likely from the plenum gasket leaking. Get Fel Pro gaskets for the plenum, Don't use the ones that Hughes gives you. You didn't say how many miles on it, Assuming it's over 100K and no issues with the 02 wiring it's probably in need of new sensors. Use NTK's!
