1996 dodge ram 3500 4x4 speedo gear size.
I own a 1996 dodge ram 3500 4x4 5 spd12v truck, Just change the rear end gears to 3:54s...my tires are 235/85r16 and now the speedo is off. I was told i needed a 29 tooth gear, just installed it now the speedo reads a bit to fast. I checked the chart again and it says 29 but that's wrong. Any ideas on what gear will get me closer probably a 30 or 31 i:m thinking.
Thanks Mark.
Thanks Mark.
Looks like 31 will get you closest, as your tire height is 31.7" (rounded to 32"). Feel free to double-check - https://www.quadratec.com/c/referenc...ar-tooth-chart
2WD or 4WD? The one in my truck ended up being the short shaft style that's in my transfer case, but I believe that the 2WD transmission takes the same style gear... When I changed out my truck to 4.10 gearing in the front and rear, I found the speedo pinion gear I needed on eBay. I seem to recall that it was used, but in great shape. Unfortunately, not much is reasonably priced much anymore. Shop around. Google can help..
