2005 Ram 1500
Old Yesterday, 05:11 PM
Dustyram's Avatar
Dustyram
Dustyram is offline
Default 2005 Ram 1500
Hey folks. My truck is in great shape with one hundred, eleven thousand miles. Always cared for....not abused. Light hauling.
I've never had any issue until about a week ago. In a parking lot it wouldn't go into gear....just wouldn't. Then into gear no problem. I wasn't sure if I'd done something....I drove a day or two with no issue.
Then it seemed to kind of jump......it's done that a few times. As I pulled into home, my engine lite came on.
I've had zero issue prior to this.....no warning of any kind.
Anyone have a idea that might point me in the right direction?
Old Yesterday, 10:06 PM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
Invest in a decent OBD II scanner. You'll find plenty os uses for it over time. You can see what code is in your computer though by doing the ley dance. (Don't bump the starter. Turn the ignition on, off, on, off nd on and leave it on the third time. Any codes should show in your odometer.)
It might be something serious or it might just be low on fluid. See what code you get when you check.
Old Yesterday, 11:06 PM
Dustyram's Avatar
Dustyram
Dustyram is offline
Thank you very much. I will give that a try.
Quick Reply: 2005 Ram 1500
